I am trying to trouble shoot some DTC codes on my VW.
Codes are:
P1136 Long term fuel trim, idling, bank 1 - system too lean
P0507 Idle control System RPM high.
I am basically looking for a intake leak of some kind. I have applied vacuum to the Cut-off valve and it does not hold vacuum. This valve is installed in the air intake to the Turbo. (you can see the valve if you follow the hose off my vac guage) Should this be able to hold vacuum?
Codes are:
