Originally Posted By: poiuy223
Keeping to the topic of this fuel system cleaner and not wanting to create another topic...
Does anyone think it would be "better" if I used a fuel system cleaner and paired it with the same brand of gas?
Shell V-Power w/ Shell gas
Techron w/ Chevron gas
I know mixing certainly won't be an issue, but since the general consensus about using oil (even though you can mix and match all you want) is to use all quarts of the same brand and weight for the sump, I figured that it should somehow apply to fuel as well. Comments?
If you're being severely OCD why not? Just be sure to only do the minimal dosage. Especially with a newer vehicle. If it treats 'up to 20 or 25' gallons, figure out how many gallons/ounce of the product it claims will do this and use the exact amount for an entire fill-up with Shell V-Power 93 octane; if you go that route.
For example, 15 ounce bottle that treats up to 25 gallons(random): 6 ounces/10 gallons of gasoline.
Should be all your new vehicle needs with the amount of driving you do, anyway. If it's mostly highway, gasoline should be able to keep it relatively clean, JMO.
