I'm planning to change the (manual) transmission oil on my 1970 MG Midget. The original specification was to use 20W-50 engine oil in the Spridget. The consensus back in the day was that the usual GL4/GL5 gear lube then used in most manual trannys was incompatable with the yellow metals in the synchros, so regular motor oil was specified. When Mobil 1 and the other synthetics first came out, people tried them, but found they didn't work very well. My recollection was that the synthetics were too "slippery" for the synchros to work properly, causing shifting problems, so people stayed with regular oil. So here we are in the modern world, with reduced ZDDP in motor oil, enhanced friction modifiers, special MT fluids and who knows what else and I'm wondering whether there's a better choice than sticking with the old reliable Castrol 20W-50. My initial thought is that modern oil isn't a good choice for the low temperature, high shear conditions in the trans, or is at least not optimized for those conditions. Would a synthetic motorcycle oil having friction modifiers for wet clutches be a better choice? One of the new special MT fluids? Is modern gear oil now compatable with the yellow metals and a better choice? It's an unusual application, and I'd appreciate any input.
