Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
How often should I change my oil.
by Greatwhite7
06/28/16 07:01 AM
'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
72 registered (Benzadmiral, 69GTX, bbhero, AirgunSavant, 2015_PSD, Astro14, 9 invisible), 1375 Guests and 9 Spiders online.
58295 Members
66 Forums
250920 Topics
Page 1 of 4 1 2 3 4 >
#2155469 - 01/30/11 12:44 PM How to post used oil analysis results
wwillson Offline
Administrator
Loc: Naperville, IL
All,
Please post oil brand/grade, oil miles, vehicle miles in subject line.
Posting images is discouraged because links tend to break over time.
We prefer that you use a code block because the text remains aligned in the post the way it is typed. You can maintain a UOA history in a text editor like Notepad or Wordpad, then simply paste the text into the code window. To post in a code window simply click on the # symbol in the full reply screen like this:
Code:
OIL             GC0w30   GC0w30
MILES IN USE    4.4k     4.6k
MILES           152.5k   148.1k
SAMPLE TAKEN    10/27/07 7/21/07
ALUMINUM        2        3
CHROMIUM        0        1
IRON            12       17
COPPER          14       13
LEAD            22       19
TIN             0        0
MOLYBDENUM      6        18
NICKEL          0        1
MANGANESE       0        0
SILVER          0        0
TITANIUM        0        0
POTASSIUM       6        10
BORON           5        12
SILICON         7        9
SODIUM          19       24
CALCIUM         1866     2013
MAGNESIUM       525      424
PHOSPHORUS      842      797
ZINC            1082     1041
BARIUM          0        0
INSOLUBLES      0.4      0.3
WATER           0        0
FLASHPOINT F   415      395
SUS VIS 210F   66.8     67.7
cSt @ 212F     12.11    12.33
Please do not post like this as it is very hard to read:
IRON 9 8
CHROMIUM 0 0
LEAD 0 0
COPPER 2 4
TIN 0 1
ALUMINUM 2 4
NICKEL 0 0
SILVER 0 0
SILICON 14 33
BORON 45 93
SODIUM 0 0
MAGNESIUM 9 13
CALCIUM 1901 2795
BARIUM 0 0
PHOSPHORUS 845 877
ZINC 920 1004
MOLY 227 48
TITANIUM 0 0
VANADIUM 0 0
POTASSIUM 0 0
FUEL <1 <1
VIS 100 7.07 10.03
WATER 0 0
COOLANT NO NO
TBN 3.78 1.86
OXID N/A 31.0
NITR N/A 30.0
or like this:
Aluminum 6/ 3/3/3/2/2/3/2/3
Chromium 1/ 1/1/1/1/1/1/1/1
Iron 32/ 26/19/20/10/12/31/9/16
Copper 22/ 32/25/42/44/56/63/52/118
Lead 10/ 9/7/10/5/5/6/4/8
Tin 1/ 2/0/2/1/3/6/3/3
Molybdenum 6/ 7/5/11/10/60/74/65/68
Nickel 1/ 1/1/1/0/1/1/0/1
Manganese 2/ 1/1/1/1/1/1/1/0
Potassium 2/ 0/1/3/3/3/2/2/0
Boron 2/ 0/3/10/17/140/152/119/157
Silicon 10/ 9/8/10/10/12/23/37/14
Sodium 2/ 3/2/3/3/6/6/2/9
Thanks,
Wayne
Edited by dnewton3 (04/29/13 11:11 AM)
#2155474 - 01/30/11 12:52 PM Re: How to post used oil analysis results [Re: wwillson]
21Rouge Offline
Loc: Vinegar Hill
Originally Posted By: wwillson
All,
For sure Wayne. And as been suggested in the past it would be very convenient if bobistheoilguy.com would upgrade and host such jpegs (as do many other forums) which would ensure the future integrity of these important links.
Edited by 21Rouge (01/30/11 01:03 PM)
#2155481 - 01/30/11 01:01 PM Re: How to post used oil analysis results [Re: wwillson]
Andrew MKZ Offline
Loc: USA
Thanks for posting. This will sure help members on this site, and the information will always be here.
2010 Lincoln MKZ
23,500 miles
Formerly DT466E_bus
#2155561 - 01/30/11 03:05 PM Re: How to post used oil analysis results [Re: wwillson]
Steve S Offline
Loc: East of IGO
Is there any way to make a pre set form where all we do is plug in the numbers? then all the uoas will have the same format?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2155673 - 01/30/11 05:30 PM Re: How to post used oil analysis results [Re: Steve S]
wwillson Offline
Administrator
Loc: Naperville, IL
Funny you should ask this question now. We are thinking the same thing and looking for a developer who could build the application.
Wayne
#2157977 - 02/01/11 06:31 PM Re: How to post used oil analysis results [Re: wwillson]
gathermewool Offline
Loc: New England
Is there an easy way to post code? I copied and pasted and tried lining everything up, but half an hour later I'm still not finished inputing only 5 UOA. I gave up when the lines were jumping and not lining up. I'm sticking with posting pics unless you guys can find an easier way...
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#2158252 - 02/01/11 11:42 PM Re: How to post used oil analysis results [Re: gathermewool]
Bill in Utah Offline
Loc: UT
Its not that hard. I just copied and pasted the example of what not to do in Wayne's example here;
Code:
IRON        9 8
CHROMIUM    0 0
LEAD        0 0
COPPER      2 4
TIN         0 1
ALUMINUM    2 4
NICKEL      0 0
SILVER      0 0
SILICON    14 33
BORON      45 93
SODIUM      0 0
MAGNESIUM   9 13
CALCIUM  1901 2795
BARIUM      0 0
PHOS      845 877
ZINC      920 1004
MOLY      227 48
TITANIUM    0 0
VANADIUM    0 0
POTASSIUM   0 0
FUEL       <1 <1
VIS 100  7.07 10.03
WATER       0 0
COOLANT    NO NO
TBN      3.78 1.86
OXID      N/A 31.0
NITR      N/A 30.0
Took me exactly 2 mins to format.
Try it in the test forum.
Bill
PS: Send me what you have in a PM and I'll line it up and send it back to you so you can see what it looks like!
Edited by Bill in Utah (02/01/11 11:44 PM)
Edit Reason: added the PS
#2237384 - 04/19/11 08:56 PM 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 [Re: wwillson]
labman Offline
Loc: Nothern USA
I was late sending it in, but here is the report for the one year run of my truck. It doesn't see a lot of miles. I have a few more months to go on my first year run on my Cavalier.
MAKE/MODEL: Isuzu 1.8l
OIL TYPE & GRADE: Mobil 1 5W/30 FUEL:Gasoline(Unleaded) OIL USE INTERVAL:2,000 Miles
Thanks for the note. This is a gas engine, and that changes a lot. Your wear numbers have
increased since last sample, but they're still normal for this type of Isuzu gas engine (compare to averages, which are based on 4,700 miles on the oil). The fuel % we calculated last time was also wrong. If you'd been using a diesel oil it would have been 4.0%, but with a gas oil it was just a trace. (We calculate fuel off the flashpoint, and the "should be" flash for a gas oil is different than a diesel oil.) Note silicon--a sealer/lube? If not, check the air filter. The TBN is strong at 5.7.
Code:
Sample Date  12/15/09
Make Up Oil    1 qt
ALUMINUM        4
CHROMIUM        2
IRON           17
COPPER          7
LEAD           15
TIN             2
MOLYBDENUM    103
NICKEL          1
MANGANESE       0
SILVER          0
TITANIUM        0
POTASSIUM       3
BORON         105
SILICON        90
SODIUM          8
CALCIUM      2483
MAGNESIUM      14
PHOSPHORUS    714
ZINC          800
BARIUM          0
                             Values Should Be*
SUS Viscosity @ 210F  55.3          55-62
cSt Viscosity @ 100C   8.86      8.8-11.1
Flashpoint in F      330           >365
Fuel %                  1.5         <2.0
Antifreeze %            0.0          0.0
Water %                 0.0          0.0
Insolubles %            0.3         <0.6
TBN                     5.7
Edited by Bill in Utah (06/07/11 01:04 PM)
Edit Reason: Whew... tried to clean up formatting so the page fit on the screen
#2240163 - 04/22/11 12:32 PM Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 [Re: wwillson]
Bruce T Offline
Loc: Oklahoma City
Hosting jpg files or developing an automated application would be helpful,
although it would require additional disk space and money to make it work.
Yes! The code block method has been improved! I tried it in the Test Forum.
The spaces between columns used to disappear when you posted and ruined
the column alignment. Now, every space I typed in the post was saved.
#2273759 - 05/29/11 08:38 AM Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 [Re: wwillson]
swingwing Offline
Loc: Texas
Having trouble formatting (Test Forum). I click on the # sign and paste my data. Everything looks great until I click on Preview Post, then columns collapse. Suggestions on what I'm missing. Car in Test forum is 2002 BMW M5.
2008 Ford Sport Trac Adrenalin - DD, AMSOIL Sig Series 0W-20
2007 MB C230 Sport - AMSOIL 5W30 Euro
#2287961 - 06/14/11 02:59 PM Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 [Re: wwillson]
Bruce T Offline
Loc: Oklahoma City
Swingwing, it is a little tricky to put your UOA in a code block. Copy and paste the text from another document. You can always manually type the text, but then you have no permanent copy saved on your computer.
If necessary, correct any issues with the column spacing. When you're ready, click and drag your mouse to highlight your UOA, click the # button, four choices will drop down, click on the fourth option. It will add the commands to start and end the code block. When you click on "Preview Post," the UOA should be in a code block.
I usually manually type the commands to start and end the code block, but I can't repeat the full commands here or I will unintentionally create a code block inside this reply. Aaargh!
#2287973 - 06/14/11 03:20 PM Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 [Re: wwillson]
Bruce T Offline
Loc: Oklahoma City
Sorry, swingwing, I just found the UOA where you had already figured this out:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2274025&page=all
#2437514 - 11/17/11 05:14 PM Re: How to post used oil analysis results [Re: wwillson]
Alamogunr Offline
Loc: Alamo, TN
I'm trying to follow the directions to post a UOA. I must be dense. I can't find a # sign on the full reply screen to post code so the numbers remain lined up in the post. HELP!
John
W.TN
#2437632 - 11/17/11 07:18 PM Re: How to post used oil analysis results [Re: wwillson]
Quattro Pete Offline
Loc: Great Lakes
Just type [code] before the text you want to show as coded...
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2437633 - 11/17/11 07:18 PM Re: How to post used oil analysis results [Re: wwillson]
Loc: Great Lakes
...and then [/code] after it.
