I have used water injection as a combustion chamber cleaner. I was wondering if hydrogen peroxide (3% store grade) would do a better job. It is basically water with an extra oxygen molecule. When it decomposes it becomes H20 and O2. I was thinking that the extra oxygen might combine with the carbon to form CO2. I have read that it can also combine with other compounds to form an acid. I was also concerned if the extra oxygen would attach itself to the iron in the cylinder and cause increased wear, or remove oil from the cylinder wall.
any thoughts?
any thoughts?
