How much do you think you'd have to overfill the oil in order to get excessive oil drawn up into the throttle body or intake manifold?
I own a 2005 Pruis and over at Priuschat forums I'm often getting into disagreements with people who only fill their oil to about half way (between empty and full marks) on the dipstick. They say that if the oil is too full it increases drag on the crank and can cause excess oil to get drawn into the intake.
I don't overfill but, but obviously I like to take it to the top mark on the dipstick. I'm pretty sure you'd have to significantly overfill (not just fill to the top mark) in order to get any bad effect like the above.
See for example this video : http://www.youtube.com/watch?v=7XvaDjKNHoI&feature=player_embedded
Notice how he's specifically saying not to fill it all the way. The fill spec is 4.1 quarts, which is probably a dry fill spec since 3.6 to 3.8 normally gets me about there on a drain and refill. A heck of a lot of people over at priuschat actually say to only use 3 quarts, which doesn't quite get you even half way on the dipstick. This seems like a totally daft idea to me, to deliberately leave yourself nearly a quart short on a refill.
What's peoples opinion on this.
