Here are the latest PDS for Super Tech 10W-30 and 10W-40 from WPP.
10W-30
Physical Specifications
Procedure Test Min Max Typical Results
ASTM D4052 Specific Gravity at 60°F NA NA 0.8717
ASTM D287 API Gravity NA NA 30.83
ASTM D445 Viscosity at 100°C, cSt 9.3 ASTM D445 Viscosity at 40°C, cSt NA NA 67.73
ASTM D2270 Viscosity Index NA NA 138
ASTM D1500 ASTM Color NA NA 2.5
ASTM D5293 Cold Cranking Simulator, cP NA 7000 6249
ASTM D5185 Zinc, % mass NA NA 0.085
ASTM D4951 Phosphorus, % mass 0.06 0.08 0.077
ASTM D5185 Calcium, % mass NA NA 0.214
ASTM D5185 Molybdenum, % mass NA NA 0.0079
ASTM D5185 Boron, % mass NA NA 0.023
ASTM D4951 Sulfur, % mass NA 0.5 0.309
ASTM D5762 Nitrogen, % mass NA NA 0.102
ASTM D874 Sulfated Ash, % mass NA NA 0.92
TM
Conventional 10W-30 API Performance SN/GF-5
• Super Tech Conventional Motor Oil contains only the highest quality, hydro-treated lubricating oils and a technologically advanced additive system, which includes detergents, dispersants, viscosity improver, anti-wear and anti-friction agents as well as oxidation and corrosion
inhibitors.
• Reduced friction for excellent protection against wear and improved fuel economy
• High resistance to viscosity and thermal breakdown
• Meets or exceeds the latest North American vehicle warranty requirements API SN and previous API engines classifications SM, SL, SJ, SH
and ILSAC GF-3, GF-4 and GF-5.
12/9/2010
10W-40
ASTM D4052 Specific Gravity at 60°F NA NA 0.8710
ASTM D287 API Gravity NA NA 30.96
ASTM D445 Viscosity at 100°C, cSt N/A N/A 15.33
ASTM D445 Viscosity at 40°C, cSt NA NA 106.5
ASTM D2270 Viscosity Index NA NA 152
ASTM D5293 Cold Cranking Simulator, cP NA N/A 6771
ASTM D5185 Zinc, % mass NA NA 0.091
ASTM D4951 Phosphorus, % mass 0.06 0.08 0.079
ASTM D5185 Calcium, % mass NA NA 0.169
ASTM D4951 Sulfur, % mass NA 0.5 0.315
TM
Conventional 10W-40 API Performance SN
inhibitors.
12/9/2010
