Originally Posted By: bigdreama
It's blue and they call it their marine stabilizer. I will probably try it once I use up my old red Stabil.
This may work....from what I've been told it "does" they market it towards "marine" use in particular since those engines are very picky in what gas they take....but really, when they talk about raising it to 15% - all older vehicles will be "picky" so I'd say give it a shot.....
But there are other alternatives.
Originally Posted By: MNgopher
Ethanol is over 100 octane, so octane depletion is not an issue.
I've heard this mentioned many times, YES, ethanol by nature is high octane, which is why they are giving us "less" gas - so in the end, they give us less "gas" but are able to meet the "AKI" requirement since ethanol by nature is a high octane.....
Quote:
Lower energy content and the corresponding decrease in fuel efficiency is an issue, though the power is not.
yep, it's been mentioned before something related to the "BTUs" - ethanol has a higher burn temperature or something (hence being higher octane....so they have to "buffer" it with gasoline).
As far as products for anti-ethanol; there's been similar threads asking this same question on nearly every auto forum.
Sta-bil Marine product (as mentioned above) is said to work.
Sta-bil also has an "orangish" product that comes in a 16-20oz. bottle that you measure dosage per gallon(s) of gas....WM "previously" had a large end cap display of it at my WM but have not seen it in a month or 2...which is said to curb ethanol effects somewhat.
Starbrite/Startron - There seems to be a big hub-bub around this product, touting "enzymes" that rejuvinate gasoline, and can spring life back to ethanol-laced gasoline. This product is sold in a 6 or 8 oz. bottle at my local WM in the Sporting Goods department, with the marine accessories....according to the bottle, 1 bottle treats up to ~128 gallons....and believe me, it's a very small bottle....lol. The bottle says you only need like 1 oz. per 16 gallons. The stuff is quite pricey though, at $9-$10....but as mentioned, there seems to be a big underground craze about this stuff....lol.
Personally, I've just been using Marvel Mystery Oil, at 3-4 oz. per 10 gallons of fuel. It's a light weight oil that adds some needed "lube" to the dry ethyl alcohol (ethanol's scientific name), resulting in a better burn, lubrication of the fuel system, pumps, injectors, and is also said to leave a "light film" of oil across the injector, rather than dry gasoline, so the injector(s) are less prone to be clogged. Driving my Dodge Aries I'd be in trouble if I lost an injector
it only has 1
hehe
