Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
7 minutes 43 seconds ago
Keep America's Nuclear Power Stations Running
by Shannow
Today at 12:14 AM
Lubegard Biotech,my thoughts
by Marco620
Today at 12:03 AM
Frivolous lawsuit loser pays court cost !
by HTSS_TR
Yesterday at 11:49 PM
cold seizure on a small air cooled engine?
by motor_oil_madman
Yesterday at 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
Yesterday at 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
Yesterday at 08:39 PM
Firestone TF2876 C&P
by holdorf333
Yesterday at 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
Yesterday at 08:30 PM
Got to experience cornering ABS today
by LoneRanger
Yesterday at 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
Yesterday at 08:03 PM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
27 registered (BigRalphie, alcyon, 2009Edge, bvance554, barkingspider, bdcardinal, 2 invisible), 982 Guests and 11 Spiders online.
58332 Members
66 Forums
251067 Topics
Page 2 of 2 < 1 2
#2589224 - 04/04/12 07:34 AM Re: What problems using kerosene in a diesel? [Re: TiredTrucker]
Cujet Offline
Loc: Jupiter, Florida
Originally Posted By: TiredTrucker
[quote=bullwinkle]
Really? 2-cycle oil will up the lubricity considerably? Not according to this study...http://www.natbiogroup.com/docs/education/lubricity%20additive%20study%20results.pdf
That study shows that a comparatively tiny quantity of the cheapest 2 stroke oil makes a huge difference. A 0.5% concentration results in a 162 micron improvement. At the tested 200/1 ratio, the cost is mere pennies per tankful.
My tests were done with Penzoil TCW-III Semi Synthetic Premium outboard oil at 100 to 1, a better oil, at twice the ratio. Plus I also used a double dose of Stanadyne Lubricity additive.
I spoke with the HFRR rig tech, he has been doing diesel fuel testing for years. Hence the 3 samples I sent in. They were not my original "guesses" but rather suggestions from the tech, tailored to my engines' needs.
It was his way of showing me what was required to make Jet-A work properly in a precision diesel. You know what? He was right. It took significant additives to make Jet-A meet the requirements.
FYI, there was some discussion between us about the film strength of the 2 stroke oil preventing metal to metal contact and that the Stanadyne product helps prevent scaring when that film strength is insufficient. It was his contention that they were somewhat different in modes of protection.
Turbo's rule.
#2598426 - 04/13/12 09:38 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Stephen_G Offline
Loc: Mount Holly New Jersey
When i was in the USAF we had several trucks that were certified to run on JP4 (JetB) JP8 (JetA) and Diesel, only thing it said was, performance on jet fuel was lower by a little bit, like top speed was 2mph slower than the diesel only one.
Diesel has to meet cetane requirements, which is similar to octane in gasoline
Kerosene has to have no sulfur due to it being a heating fuel (imangine the smell)
Jet Fuel has to have more additives and meets stricter requirements for water than Diesel and Kero, but has next to none for sulfur.
If you are going to run Kero in a diesel, ensure you put a gal of diesel in to ensure you get some sulfur into it for the fuel pump, new diesels are not as picky for the sulfur as they are designed for ultra low sulfur diesel, but older ones are very picky, read up on the GM 350 Diesel and the fuel pump problems due to ULSD. Use at your own risk.
#2599970 - 04/15/12 05:39 AM Re: What problems using kerosene in a diesel? [Re: JHZR2]
Shannow Online   content
Loc: Oz
Originally Posted By: JHZR2
Kerosine ha a different viscosity characteristic - not necessarily good for moving parts. Believe the aromatics may have been all removed too.
Yeah, back in the day, we used to fill industrial gearboxes with kero and "lap" the gears in under very light load.
aromatics aren't very good in an inside lamp/heater.
Page 2 of 2 < 1 2
