I have read on some internet sites that a honda 3000 inverter gen-set would not run a furnace, and even saw one where a 5000 watt non-inverter would not run a furnace. Other post talk about 2000 watt inverter gen-sets working fine with a furnace or AC. And some have problems with 2000 watt inverter gensets running an AC.
Different manufacturers and model of furnaces and AC units seam to have different requirements regarding what generator will work with them. It really does seam to be a hit or miss thing, that you should check before you can be sure it will work.
Some fancy furnaces like the ones that pulse, or regulate the speed of the fan, and some others seam to be more of a problem to run from a generator. Also older AC units, or low efficiency units seam to draw too much at start-up. If you were running one of these from a genset, you should either get someone who has a generator to test that that size will work before you buy it, or go for something with a lot of reserve capacity.
Also, because you have to have your gen-set far from the house so you do not get any carbon-monoxide into the house, be sure you have a heavy enough gauge of wire for the amount of current and length of wire. I suspect that about half of the time people can not get a generator to run a furnace or AC unit, they are using too light a gauge of wire.
So I ran the our forced air furnace from the Generac iX2000 today to be sure that it would work properly. Even in eco-mode it ran the furnace fine with a few compact florescent lights and a small TV , cable box, and DVD player powered up.
Previous current readings for the furnace were 6 amps running, and 10 amps peak. So I expected that it could handle it along with some room light, and the small TV, and everything worked.
The only thing I did notice was in eco-mode, at the instant you turn on some compact florescent lights the TV will shut down, and if the furnace is running, it will shut off the gas, and then go into the re-light the gas sequence of running the draft blower then the igniter, and then the gas. The forced air fan stayed on through-out this.
Running a furnace or a AC unit from a generator can be a hit or miss thing, and you really only know that a given generator will work with a given furnace, or AC unit after you actually run them together.
When the furnace cycles on it did does not cause the TV to shut down. Only turning on compact fluorescents to any room caused the TV and gas to the furnace (if it is running) to drop out.
Ran the generator without eco-mode and the drop out of TV and furnace did not happen when compact florescent lights were turned on.
I also tested that the generator can run the fridge when the breaker to the furnace is off. It works fine.
The starting current for the fridge was previously measured at 11 amps. Starting the fridge with furnace, room lights, and small TV would exceed the peak power rating of the generator, and was not tried.
Bottom line, the Generac iX2000 can run our furnace, compact florescent room lights, and small TV. But not the fridge and furnace at the same time. It is light enough for one person to move it from the cellar to the far end of the back yard (this is a real big plus).
Because it is an inverter design, in the eco-mode it will get over 4 and a half hours form one gallon of gas. I rigged up an add on tank cap from a honda compatible gas cap that I got at lows for five bucks. Connected to an external 5 gallon tank, + the one on the generator it should run for 27 hours.
I broke it in with the supplied straight 30 weight oil when the ambient was warm enough. Now I am running GC in it and plan on changing it every 100 hours.
I think the Generac iX2000 is a good value, and a good generator for running most common simple design forced air furnace.
