Originally Posted By: Cogito
I've got an 89 RT4WD Civic wagon, but have it setup for FWD. I blew my left rear tire the other day, so I pulled into a small tire shop and bought a used tire since the other 3 are about half worn out. I just noticed that it is a 185/65-14, whereas my other tires are all 185/70-14. I'm wondering whether I should go back and complain, or just keep it? It's so close, and it's on the rear, I was thinking it won't make much difference? I haven't noticed any handling issues, but I don't want to somehow screw up the suspension somehow. What do you guys think?
What do you mean that you have it set up for front wheel drive(FWD)? I'm not sure that I understand?
I realize that this particular '89 Civic Wagon is FWD by it's design w/AWD optional. Explain more please! Has the driveshaft been eliminated?
The 65 series tire is almost 1"(.8") lower than the 70 series tire. If there is a rear differential, this will effect the gearing. It's like being in a turn all the time. The left rear tire is turning faster than the right rear tire. If you only had FWD, this wouldn't matter with the exception of safety/handling. But as long as you know what's on your car, drive accordingly!
Personaly, I would have all the same size tires on the vehicle. Or change the other rear tire to match.
