I stitched to PP this run and did not use the remote start but the lead continues to increase and now Tin is up as well. I had wanted to stretch the OCI out to 6K and based the many posts on BITOG, both PP and PYB are very good oils. I'm thinking about switching back to Castrol GTX or possibly something else because the UOA was much better on GTX, even on a new engine. Vehicle is 2009 Silverado Crew Cab 5.3L with AFM. 75% Highway driving. Please help! Thanks
Blackstone Comments: Unfortunately, we still can’t recommend 6,000 miles on the oil. Most of the wear metals look good but lead and tin are considerably higher than average. Than means that this 5.3L is seeing some excessive bearing wear. This level might be normal for this engine and the use that it sees, but until we know that for sure, stick with 3,000-4,000 miles on the oil. Fuel at 1.0% isn’t cautionary and the viscosity was normal for 5W/30. The TBN was strong at 4.6 showing lots of active additive remaining. Hopefully the bearings look better the next time.
/PP / /PYB /GTX
MI/HR on Oil /3,772 /Unit Avg /2956 /3135
MI/UR on Unit /23,771 / /19,999 /4843
Sample Date /05-04-2011 / /02-20-2011 /05-07-2010
Make Up Oil Added /0 /0 /0
Aluminum /2 /3 /3 /3
Chromium /1 /1 /1 /1
Iron /10 /13 /9 /19
Copper /49 /93 /40 /190
Lead /27 /20 /24 /10
Tin /8 /5 /3 /3
Molybdenum /74 /108 /246 /5
Nickel /1 /1 /1 /1
Manganese /1 /3 /1 /6
Silver /0 /0 /0 /0
Titanium /0 /0 /0 /0
Potassium /0 /1 /0 /3
Boron /14 /29 /69 /4
Silicon /13 /16 /12 /23
Sodium /4 /93 /5 /269
Calcium /2411 /2272 /2267 /2139
Magnesium /10 /8 /7 /7
Phosphorus /693 /695 /717 /675
Zinc /705 /782 /779 /863
Barium /0 /0 /0 /0
Values
should be
SUS Viscosity @210F /56.3 /56-63 /54.3 /55.8
cSt Viscosity @100C /9.15 /9.1-11.3 /8.58 /9.00
Flashpoint in F /345 />365 /375 /400
Fuel % /1.0 / Water % /0.0 /0.0 /0.0
Insolubles % /0.4 /0.2 /0.3
TBN /4.6 /4.3
/PP / /PYB /GTX
Iron /10 /13 /9 /19
Tin /8 /5 /3 /3
Nickel /1 /1 /1 /1
Silver /0 /0 /0 /0
Barium /0 /0 /0 /0
Values
should be
TBN /4.6 /4.3
