I got the truck with 50k miles on it. I put the last 75k miles on it. It had crossed my mind that the initial owner may have mistreated it. I bought it with the certified pre owned toyota warranty, thinking if there were problems they would arise before now. Oh well I may not ever know exactly why this happened. I will say I was happy to see how clean the engine was. I may even re use my heads on the donor motor which is out of a 96 4Runner. Supposively has 100k miles on it. When it broke down I looked underneath the truck to see if it was gushing oil....nope, then I pulled the dipstick.... it was on the full mark...then I towed it home, plugged in the code scanner thinking I was fixing to get somewhere, you know this thing never set off a CEL?? I dont get it really I dont. I even checked for codes about 3 times, nada.
Im fixing to get after this engine swap, hoping for a successful outcome. I was thinking I would check the compression in the donor since it came attached to a transmission with a starter. Anyone know how accurate/useful those cold engine compression readings would be?
