Originally Posted By: btanchors
I have the same question that Artem originally posted, and I haven't yet seen an answer...I was the one who posted the VOAs of Mobil 1 AFE 0W-20 and Mobil 1 5W-30 EP. Both of those had high TANs as well - I had been expecting readings of less than 1.0. Why the high TAN?
I have one vehicle that uses 0W-20, and two that use 5W-30. I'm using the aforementioned Mobil 1 oils for these vehicles.
My intent is to continue with the Mobil 1 SN oils for now, but will closely evaluate after I have performed a few UOAs. If I don't like what I see I may well switch over to the Amsoil. I would be very interested in seeing a VOA of Amsoil's 0W-20 as well.
Yea i'm waiting for someone with some knowledge in the TAN department to answer that question as well. I also thought TAN should start out low in the +/- 1.0 range.
I remember someone saying that once TAN and TBN are equal, the oil should be changed. Well since TAN starts out so high, i'd have to change the oil sooner then 10k (speaking from my past UOA where TAN was 4.4 and TBN 3.1 using SSO after "only" 10,000 miles.
I'm lost.
Anyway, i doubt i'll do a VOA on their 0w20. Seeing as Blackstone's TBN count is so close to what Amsoil posted on their website (12.6) and seeing as ASM has the same count (its also now a Signature Series oil), i think its safe to say the blends should be very similar with just viscosity's being the difference.
