Originally Posted By: dlafoy
When one particular oil(0w) is able to flow quicker upon startup than another particular oil( 10w) and as a result of this quicker flow your engine's internals receive the protection of oil sooner than another oil could give it, hence the term "BeTTeR" .
So if something is "better" then where are the engines that have been damaged over the decades using non 0 weight oils? Where are inferior oils not protecting the engine parts on start up since they don't flow "quicker" than 0 weight oils?
Which model engine is dry when starting up and they NEED the "better" 0 weight oils for protection?
I don't fall for marketing so I'd love to have these simple questions covered. Because if it was true (ie "case closed") that 0 weight oils were "better" every mfg would require its use and every oil company would make only 0 weight oils.
Originally Posted By: RegDunlop
Bill not sure where you were insulted.
Read the PM I sent you.
Bill
Bill
