Royal Purple HPS
Originally Posted By: dubie2003
I believe there is already a thread on this. Something about them finally meeting API specs and etc....
There is a thread on EVERYTHING here... duplicates are bound to happen.
Well they already claimed their normal SL stuff already had higher than SM levels of zinc. Find me one VOA or UOA that shows that. Ha!
There everywhere!!
The 5W20, 5W30, and 10W30 have 1000ppm of ZDDP while the 10W40 and 20W50 have 1200 ppm of ZDDP for the regular RP
Uh... ANY one of them on the UOA/VOA forum...???
OK this time I did find some of these readings approaching 900-1000. Never could before. Seems like the thinner stuff comes up in the 800-ish range.
I had expected the error to center around the stated 1100 ppm and am a little disappointed that I dont see that.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1918383&page=1
http://www.bobistheoilguy.com/forums/ubb...rue#Post1025149
http://www.bobistheoilguy.com/forums/ubb...rue#Post2204642
http://www.bobistheoilguy.com/forums/ubb...rue#Post2048249
http://www.bobistheoilguy.com/forums/ubb...rue#Post1972520
If anyone wants to donate to the cause, I'll buy a bottle of the new HPS and send it off for a VOA.
The guys at two different AutoZones had no clue what I was talking about when I asked today.
Thats not too surprising actually.
Quote:
This unique blend enables HPS to outperform leading synthetics and conventional lubricants.
Finally something that outperform all other leading synthetic & conventional oils. Mods, please update "What is the BEST oil?" sticky now.
hahaha <3
Here is my VOA/UOA of RP5W20. No 1000 PPM here. Not that I think it has to be there in my case. This result is from Wearcheck.
Silicon: 0/19
Potassium: 8.5/5/1
Sodium: 7.1/15
Fuel %: 0/ Glycol: 0/0
Water: Sulfation: 0/23% of max
Nitration: 0/16 % of max
Boron: 14/5.9
Barium: 1.3/0
Calcium: 2524/2280
Magnesium: 1252/1164
Moly: 170/118
Phosphorus: 872/825
Zinc: 862/908
Vis @ 40C: 50.83/--
Vis @ 100C: 9.31 cSt/8.9 cSt
VI: 168/--
Oxidation:0/27 % of max
TBN: 13.6/10.0
Iron: 3.7/28
Nickel: 0.5/0.5
Chromium: 0/1.7
Titanium: 0/0.2
Copper: 0.1/4.4
Aluminum: 1.3/5.3
Lead 1.4/0
All other values: 0
That is not the same oil. I was referring to a VOA of the HPS.
My bad.
Originally Posted By: Jim Allen
Here is my VOA/UOA of RP5W20. No 1000 PPM here. Not that I think it has to be there in my case. This result is from Wearcheck.[...]
That was my point also. I'm not saying RP is bad oil--I've used it myself.
I am just still skeptical of the zinc/phosphorous content being as advertised. (And that includes the new stuff.)
