Yesterday, I took my friend's 2006 Prius w/85k to the local Toyota dealer for scheduled maintenance. On the agenda for this visit was an oil change, vehicle inspection, clean/adjust of rear drum brakes and a transmission fluid drain and refill. They did give me a very fair price on the service, which is $140 total for all 3 items. During the inspection, they found a LF axle seal leak, which is said to be common according to the Priuschat gurus.
The Toyota CPO warranty is covering the axle seal repair after the $50 deductible. For the repair, the warranty is covering the labor, axle seal, axle nut, cotter pin, and 1 quart of WS transmission fluid for top-off. According to Toyota, it is not necessary to drain the fluid in order to replace the axle seal. Therefore, my requested transmission service is an entirely separate operation and there is no crossover on the labor time.
Having replaced an axle seal before, it is true in most cases that the transmission fluid does not need to be drained in order to remove the axle. However, I would have expected that since the tech needs to remove the fill plug in order to check the fluid level, they would not charge me labor to drain the fluid (one drain plug!) while they are doing the job. Am I expecting too much? Or is this just how the system works in that they can get away with charging for the 1/2 hr labor to complete the transmission service.
What do you guys think?
Thanks.
Thanks.
