hey guys i have some questions for you. I just rebuilt the carb on my weedwacker (1 year old featherlight) put new fuel lines on it and everything. I can now at least get it to run after my parents left old gas in it all year and winter. Mixed up some new 40:1 and yanked. Started right up on full choke and then continued to run after being flipped to half choke. put it on full open and the motor seemed to want to die alot.
Today started it up. It would only run half choke (it is very humid tho so there is alot of moisture in the air so idk how much that would effect mixture settings) But the motor still would not run on full open and seemed to want to bog if i just grabbed the throttle and yanked. it would accelerate super slow and sometimes die.
What does this mean? I checked all the gaskets (trimmer is only 1 year old) they all seemed pliable and new. no holes or defects. cleaned everything out. new lines. inspected the primer bulb. it was fine and still pliable. Now when the motor is running the primmer bulb becomes mostly empty of fuel.
So I can only conclude with my limited experience with carbs that the problem is its running lean? Also if anyone could tell me how to adjust the mixture settings? eg high and low? I know that because its a Weedeater it needs a special tool (gona get one after payday) Do you adjust the low first till it idles fine? then adjust high so that it runs ok at full? how do you know whats to rich and whats to lean? I would think with yard tools its better to run them rich than lean but idk.
Thanks
Sean Scott
Thanks
Sean Scott
