Car is 2007 Mazda3i, 37k miles, automatic.
There has been a slow oil leak from the vent hole where the engine meets transmission. Went to dealer 4 times, they finally said it's rear main seal. Car is still under powertrain warantee, but I really don't like them tear everything apart.
The oil pan has one side abutting the trans, I am suspecting it's likely the oil pan gasket. It's really hard to believe the rear main seal is leaking at this mileage (37k), car is garaged and never driven hard.
How could you tell if the oil is leaking from oil pan vs from rear main seal? thanks.
