So my tie rod nut was stuck, it would only spin the whole bolt since the nut was stuck, and now said nut is stripped! Two questions
-Where do I go from here with getting a good stripped nut remover?
-How do I take off this nut? (I would cut this off but there's no room between the nut and the steering knuckle)
-Is the tie rod end joint ruined now?
Thanks!
Thanks!
