Originally Posted By: mechtech2
There should be a taper on the bottom of the slide.
But there is a difference between air being forced in, vs. air being sucked in naturally. The pictures shows artificially induced forced air.
Is There??
I don't know, but I would assume that air moving from an area of High pressure to an area of Lower pressure would act more or less the same, the only difference is, that with forced induction, the gradient (or range) would be greater.
