RedLine for injector products. It really works, little pricey but worth the money. If you have been not using any injector cleaners or "top tier" fuel, use the Sl-1 at the end of your oci because it WILL clean and add insolubles into the oil. Once you have used a bottle or two then it is fine. Depends on mileage and gasoline used.
