really, valve stem leaking at 29k? No warranty of any sort? Seems kind of "early" to have to switch to a "HM" oil.....
And yea, that's interesting, I don't think the Pennzoil HM is even RC/EC rated.....hehe. Props to Mobil for accomplishing that feat
BTW, have you tried any sort of crankcase cleaner/flush product by chance.....? To see if perhaps maybe you just have some "crud" built up around the seals that isn't allowing the valve stems to seat properly? I don't know, 29k just seems to be awfully soon for these kind of problems.....then again, I'm not too familiar with this vehicle, if this is a known problem or not....
Edit: oooo....just noticed it's a 2001....! Wow, likely no warranty there then, 11 years old! hehe.
But personally, I'd give something like Marvel Mystery Oil, or Seafoam a try in the crankcase, per the directions on the bottle. 1 qt of MMO in a 5 qt. sump (1 qt MMO to 4 qts Motor Oil); anything less than 5 qts, make it easy and just dump in a pint. Run the MMO in the crankcase for 3-4k and see if it solves the problem.
Or, give Seafoam a try, at 1.5 oz. per qt, for a 5 qt fill, you're looking at 7.5 oz. of Seafoam (a little bit more than half the can). This can added pre-oil change as well as "post" oil change, and can be safely ran for 3-4k in the oil.
