I have a 1992 Chrysler Daytona 3.0L MMC
i have recently striped down the engine replaced all the seals and gaskets. after i put the engine back together i lose my oil pressure after it warms up. i was told that it was probably the main bearings so i replaced the mains and connenting rod bearings. and i still have the same issue. I'm thinking at this point it could be the oil pump. i was also told the relief valve could be getting stuck open. it does not seem to be catching to be stuck open. i also found a form that says to put a washer under the releaf valve spring. does anyone have any suggest on what is the issue and how to fix this?
thank you
thank you
