Picked up 9 tubes at walmart marked down from 4.19 to .75 but rang up as .25 a tube.
I do own a boat trailer which is used for about 3mile trips twice a month. Is this grease good enough for lawnmower spindles?
For high resistance against winter rust and corrosion. Engineered to meet a wide variety of boat and boat towing equipment requirements. NLGI #2 grade, meets NLGI's highest standards for wheel bearing and chassis lubrication (GC-LB). Inherent water and water washout resistance. Offers good rust and corrosion protection, for fresh- and salt-water use. Resistant to pounding out under pressure. Stable, will not harden or set up in storage or use. Retains consistency at high temps. High melting point. Extremepressure additives prevent metal-to-metal seizure under high load conditions and shearing forces. 60 to 65-Lb. Timken rating. This Grease Marine 14 oz is one of many top quality items in our Grease department.
