Originally Posted By: Gokhan
dbrowne1 said:Gokhan said:Rotellas
There are a lot of things that affect wear protection. A balanced antiwear and friction-modifier package is one of them. HTHS viscosity is also very important, larger being better. I prefer 15W-40 for that reason because it has a substantially higher HTHS viscosity than 5W-40.
Regarding xW-40 weight oil, you can use it virtually in any engine. It will reduce fuel economy with respect to xW-20 and xW-30 on the downside. It has superior wear protection (increased film strength, especially important for bearings) than thinner viscosities. Higher HTHS viscosity simply means higher oil-film strength. 15W-40 works very well in my gasoline engine and is the standard for diesel engines.
For newer engines you probably don't need to sacrifice fuel economy for slightly enhanced wear protection, unless you're doing a lot of high-speed, high-acceleration, and/or high-temperature driving, which could result in a lot of wear with xW-20 or even xW-30 if that is the case for your driving conditions.
Your misunderstanding of HTHS viscosity I find quite alarming.
A higher HTHS viscosity is definately NOT alway better.
The higher the HTHS viscosity of an oil the thicker the oil, and the thicker the oil the slower the oil's flow.
The old lubrication maxium always applies in chosing the correct viscosity; " as light as possible, as thick as necessary".
