I use some oil and leak a bit in my Aerostar. After trying 5W20, 5W30, and now 5W40 I found I use the least amount of oil running 5W20. I'm currently using 5W40 and will probably have to add some oil in about another 500 miles, which would put me 2000 miles into the OCI. I have a bottle of the Oil Saver sitting in my stash and I'd like to give it a try. I have a feeling my valve seals, are part of the issue, as well as a leaking gasket. It's certainly worth a shot!
At 197,000 miles I'm not putting any major money into this rig, when it dies it goes to junkyard and gets replaced. My goal is 200,000 miles and a 4x4 for next winter to replace it with. But I've said that before. LOL Thanks!
Definitely is, keep us updated!
Originally Posted By: PontiacFan
Originally Posted By: Falcon_LS
I made a habit of using it at every oil change in my Grand Marquis, along with MoS2. When I bought the car last year, it was burning oil through the valve seals and it was also leaking from the valve covers and the o-ring at the oil cooler adapter by the oil filter. Now it doesn't leak or burn any oil, and oil consumption over the course of the last oil change (6,400 miles) was less than 200 ml. thumbsup
It sounds like you are happy with this product, I would keep using it. JMO
Definitely, it's worked wonders. I have yet to come across another product that delivers the same results, especially for the moderate price of $5 a can!
Originally Posted By: ltslimjim
I wonder how "Oil Saver" would effect an extended OCI compared to MoS2? Shorten, lengthen, nothing?
No affect, just dump it in and go about your regular oil change.
Originally Posted By: Russell
Think I will use it on my almost 200,000 mile BMW. I have an oil pan leak that is irritating but not serious. I recently changed to Valvoline 20w50 HM oil and added MOs2. I think the Valvoline HM will reduce my leak a bit as it is supposed to swell seals-I think.
It is worth a try. The sealing affect depends greatly on the seal material, but it has resolved an issue my neighbor had with his a leaking crank seal on his '99 540i.
