So I had to replace a few ball joints on my pickup. I replaced two sealed upper ball joints, with new greaseable aftermarket ball joints. I greased up the ball joints via their zerk fittings with standard ball joint grease. After a few days I did a visual inspection, and to my suprise saw that the ball joint's zerks were building a large glob of grease.
It seems that they are spitting the grease back out! I checked to ensure the ball and spring seal are working, with a paper clip, on both zerks. The balls are in fact there, and the spring seems to work. It does not appear (hard to tell when greased up) that the balls are coming to the very top however.
What is going on here? I don't have much experience with zerks...since the majority of the cars I have owned have had sealed lifers.
Did I overfill these bad boys? (I filled them until I saw some fresh grease come from the bottom of the boots when I first bought them) I had to replace the upper control arms as a complete unit with the new ball joints on them, so I greased them up well before I bolted them on. Once installed, they seemed a bit overfilled, but nothing alarming.
Is this normal, or do I have a couple of cheap zerks on my hands? Or did I overfill them and the grease is coming out of the zerks?
