Originally Posted By: F430
The car has a dry sump system and to check oil, the car has to be at operating temp with car idling. I usually check the level after drive. The dip stick on the F430 is flat & wide and foams are visible on the stick when checking oil level. Referring to my owner's manual, ALL of the lubrications (trans, F1, power steering, diff, ect) recommended for the car are ALL Shell products including coolants and brake fluids.
As I said before, it's normal for the oil tank in dry sump systems to have bubbles. It's impossible for them to not have bubbles. The dipstick measures the oil level in the oil tank.
It's only a concern if much of the oil tank is foaming heavily and you see a few inches of tiny bubbles on the dipstick. The return hose is at the bottom of the oil tank so having some bubbles at the top isn't harmful.
