Originally Posted By: Rickey
That's not the way I understand the top tier formulation.
The way I read it is that the test fuel for certification testing of the top tier additive shall be additized with 8-10 percent ethanol.
http://www.toptiergas.com/deposit_control.html
In other words the top tier additive shall be capable of tolerating the addition of ethanol.
Rickey.
From the standard:
Quote:
The base fuel shall have the following specific properties after the addition of ethanol:
Contain enough denatured ethanol such that the actual ethanol content is no less than 8.0 and no more than 10.0 volume percent.
That tells me that, after the addition of ethanol, the fuel has enough denatured ethanol that the actual content is no less than 8% and no greater than 10%. It doesn't mention additives; it mentions the "base fuel". I could certainly be mis-reading it, but it seems clear to me.
The way that I read it the top tier additive needs to be capable of working with ethanol, but does not require ethanol to work.
The following sentence explains that the certification tests shall use a fuel as specified......
"1.3 Deposit Control Initial Performance Standards. Initial deposit control performance shall be demonstrated using the tests shown below." etc.
Rickey.
There are a number of initial performance standards defined in the Top Tier specifications. Each performance standard specifies a Base Fuel to be used to meet that standard. The 8-10% ethanol by volume requirement is specified in the 1.3.1.2 section, and is apparently a requirement for the test to demonstrate conformance to the Intake Valve Keep Clean Initial Performance Standard. The section even says,
"The base fuel shall conform to ASTM D 4814 and shall contain commercial fuel grade ethanol conforming to ASTM D 4806."
The Combustion Chamber Deposit Initial Performance Standard also defines a Base Fuel, in section 1.3.2.2. Coincidentally, it requires the same Base Fuel as the previous Initial Performance Standard.
The Fuel Injector Fouling Initial Performance Standard's Base Fuel options are defined in section 1.3.3.2, and there are apparently two options. There is apparently no minimum or maximum ethanol by volume percentage requirement for this Initial Performance Standard, because it is not listed.
There is a fourth Initial Performance Standard at the bottom, and its Base Fuel appears to be the same as specified in section 1.3.1.2 above.
I don't see anything in the language that talks about additive compatibility. We may just simply agree to disagree on this.
