Does anyone have a pad recommendation for the Altima in my signature? I've been very happy with the braking performance of the car so I've thought about just sticking with OEM pads which cost $82 a set.
I'm going to have the car into the dealer this coming Thursday. They're going to turn my rotors under warranty because they're slightly warped and I'm getting a bit of vibration. When the car was in in January, their report said "front pad thickness between 4 and 6 mm. will require attention soon", so I'm anticipating that they're going to suggest I put new pads on while they've got the brakes apart.
4 mm still seems like a fair amount of pad material and not worn enough to replace. Am I right? If I do need new pads, I may be paying a bit more for OEM pads, but if all I have to pay for is pads, it'll save me the time of having to do them myself later.
The stock/OEM pads (to the best of my knowledge) are full-metallics. I've been told that full-metallic pads may rust a bit after driving in wet conditions and may leave a small imprint on the rotor and over time this may lead to the minor warping of the rotors that I've experience. (I guess it's more of a build-up that causes a minor vibration than warping.) If that's true then I'm inclined to go with an aftermarket ceramic pad which won't be suspect to the rusting/imprinting.
