I've heard this before, that using the A/C more often will shorten the battery's lifespan. Why is that? The only 2 reasons I can think of are (1) the AC tends to raise underhood temps, and (2) using the AC requires the electrical fan to run more often especially when you're at a stop, thus potentially exceeding the charging system's ability to maintain the battery.
I don't believe #2 is a problem on modern cars because modern alternators are smart enough to maintain the battery. As for #1, this does seem to be a legitimate problem but not for cars whose batteries are located away from the engine like some performance cars.
Myth or real?
Myth or real?
