....so long as the second number matches the manufacturer's recommendation.
For example: The manufacture recommends 15W-50 for my area and temp. Then, I personally would use a 0W-50, so long as it also had the appropriate API service.
Can anyone who really understands oil punch a hole in that one??
My rationale- first, the manufacturer is doing 2 things by recommending the 15W-50. First, they have determined that a 50weight oil is best at operating temperature (212 F). Second, they are assuming you're using mineral oil, not synthetic. Since we know that a mineral oil of 15W50 rating would really be a 15 weight oil, with additives that will cause it to THICKEN when it gets warm, while a synthetic of 15W50 is really a 50weight that just happens to flow like a 15 weight when "cold", why would anyone intentionally (other than the $$$ issue) select a synth oil with a first number (cold flow) greater than zero??
My theory is, since we know that, when "cold", a motor oil of 15weight will NOT flow properly (when cold, neither does a 10 or a 5 or even a 0, to be honest), I want to use as low a number as possible. Ideally, I'd want a -10Wxx synthetic. THAT could be perfect....but also expensive, and perhaps impossible to formulate.
For now, in ANY vehicle I own, I use synthetic 0W-xx, where the "xx" is the actual recommended weight per the manufacturer. In my motorcycles, I run Eneos 0W-50 with SM API service (while the manufacturer recommends 20W-50 in summer).
