I've got a 2011 Scion tC with a little over 1100 miles on it. I've had it for three months, so as you can see, it doesn't get driven that much. I probably average
I take a lot of short trips (it's driven almost every day) which do not allow the water (let alone the oil) to fully warm up, and several times a month I go on somewhat longer trips where it warms up fully. The engine (2AR-FE 2.5L) requires 0W20 synthetic motor oil, which is fine since I prefer to use synthetics anyway. My plan is to dump the factory oil as soon as I get my hands on the proper tool to remove the filter housing (it uses a cartridge filter), and to use Toyota 0W20 oil and a Toyota filter. Since it comes with two complimentary oil changes, my thinking is that it would be best to use the same oil as the dealer to avoid changing chemistries every 6 months, hopefully keeping wear to a minimum.
I've used Amsoil products in the past but always in cars that were out of their powertrain warranties. Is it a problem to use non-API oils in a car that's under warranty? Do you think changing the oil every 6 months, irrespective of mileage, is a good idea? What are your thoughts on sticking with Toyota oil and filters, at least until the complimentary oil changes have been used?
I have an unrelated appointment with the dealer this Friday at which time I'll check if it's possible to use the free oil changes when I wish and not 12 months apart. Do you have any recommendations on a good oil and filer to use once I've used up the free oil changes, again keeping in mind that my engine requires 0W20?
