I think JohnBrowning is stating that in hotter climates, a thicker oil is beneficial b/c the oil film is more durable, that it doesn't shear as easily, so it's less reliant on additives for good wear qualities.quote:
Originally posted by buster:
John, your running a 15w-50 in a truck that calls for a 30wt oil. If you thought what you have stated, then why didnt' you start with a 30wt first and sampled it? What makes you think the 50wt is going to provide more protection? We've seen so many UOA's that don't suggest thicker is better in every case which is why using a heavier oil for every car all the time is not the answer. I'm also not saying thinner is better. What Im saying is not all engines require heavier oils.quote:
The OEM recomendations are just that recomendations! I think that if the OEM recomends something other then 30wt then start with their recomendation and work from their. The simply truth is that no one oil prescription is going to work universaly across the board.
He's also stated that he's not strictly pro thick oil - he has advocated all along that you should use an oil suited to the ambient temperatures that your car will experience. I agree completely with that philosophy. I live in a hotter climate and I drive with a heavy right foot, so starting out with a 15-50 made sense for me, and it seems to have worked out so far.
But maybe to satisfy the fancy of this board, i'll do two things for my next UOA's: 1) run the mobil 1 to 5000 miles on the next oil change, 2) run mobil 1 5-30 for the same interval. As far as I can tell, the mobil 1 oils all have the same additive package, so the only thing that would change would be the oil thickness.
I'll document gas mileage of the course of using the 5-30 as well.
