I just rebuilt the 265ci V8 in my 1956 Corvette. I reused the original flat tappet cam & solid lifters (in the same bores). Did a ball hone on the cylinders and used cast rings. I filled it with Royal Purple Break-In oil. I am hearing conflicting things on the internet and want to ask you guys...
How many miles should it be left in for? It know it says not more than 2,500 miles, but I’ve also been told (by CompCams specifically) that if run for more than 30mins it could wipe cam lobes.
What is the optimal run-time/mileage for using RP Break-Oil considering my engine specs? It seems too expensive to drain right away and I was going to drain and change at 500 miles but not if there is even the slightest chance that damage could be caused in that time.
Thanks!
Alex
Thanks!
Alex
