Originally Posted By: Blaze
What do they put in two stroke oil to make it properly mix and disperse in gasoline?.. thanks
They're both non-polar so they should mix well in just about any ratio. It's only when you want to get a polar/non-polar mixture that you need to start using wetting agents, ESPECIALLY getting water and anything else to mix. Dispersants are for getting particulates to not clump, like soot in a crankcase.
