Don't discount coal for a long while yet...
by Shannow
8 minutes 52 seconds ago
Decent Wireless Computer Headset?
by 99Saturn
Yesterday at 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
Yesterday at 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
Yesterday at 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
Yesterday at 10:00 PM
Fram TG 7317 6k miles
by bbhero
Yesterday at 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
Yesterday at 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
Yesterday at 08:56 PM
Second lawn mower blade
by greasegunn
Yesterday at 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
Yesterday at 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
Yesterday at 04:47 PM
Where do pets go?
by Whitewolf
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
18 registered (-SyN-, EchoTech1945, Drosselmier, clinebarger, chrisri, DavidZ28), 787 Guests and 10 Spiders online.
58272 Members
66 Forums
250819 Topics
Page 1 of 5 1 2 3 4 5 >
#2228777 - 04/11/11 07:56 AM '07 LBZ UOA @ 175,000
Meathead Offline
Loc: Upstate SC
This is an '07 Chevrolet Silverado 2500HD LBZ Duramax. The truck had 175,000 miles on it at the time of this OCI/UOA (182k or so now), running Shell Rotella T6 5W-40 since about 45,000 and using a Fram PH9100 filter (no bypass or extra filtration). The engine operates daily on a +160 tuner, as it has since about 30k. I do very little towing, and when I do, it's rarely more than 3-4,000 lbs.
Wear Metals (most recent, last):
Cu 3, 3
Fe 58, 46
Cr 1, 1
Al 3, 3
Pb 2, 2
Sn 1, 0
Si 4, 5
Na 4, 6
K 4, 2
Mo 66, 58
Ca 959, 1398
Mg 1156, 996
Zn 1356, 1456
P 1106, 1216
Oil Condition/Particle Count (ctml):
St 37, 39
OXI 18,17
NIT 10, 10
SUL 22, 22
W N
A N
F N
V100 14.6, 14.7
I welcome any informed thoughts or analysis of this sample/history.
#2228811 - 04/11/11 08:37 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Johnny Offline
Loc: Retired | Wausau, WI
welcome to BITOG
How many miles were on this oil change?
#2228827 - 04/11/11 08:51 AM Re: '07 LBZ UOA @ 175,000 [Re: Johnny]
Meathead Offline
Loc: Upstate SC
Ahh, the magic question...
Both of those were on a 25,000 mile OCI. The first was actually a bit early - closer to 23k, but the second was at 25,150.
#2228838 - 04/11/11 09:11 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Hokiefyd Offline
Loc: Virginia
I think they generally say that iron (Fe) tracks with mileage, so for 23,000 miles, this looks pretty dadgum good. Viscosity is good. Did this analysis not include a TBN (Total Base Number)?
Welcome to the forum!
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2228848 - 04/11/11 09:18 AM Re: '07 LBZ UOA @ 175,000 [Re: Hokiefyd]
Meathead Offline
Loc: Upstate SC
Nossir, it didn't. My understanding of the TBN is that it's a measure of, or a method of determining whether the oil can be used further/longer. If I'm correct about that, I would assume the TBN is in an acceptable range, as both samples/tests included the note "No problems currently associated with this sample. Continue sampling at the normal interval."
Feel free to correct me if you think that's an unsafe assumption.
Thanks.
#2228936 - 04/11/11 11:00 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Jim Allen Offline
Loc: NW Ohio
This is an outstanding UOA. I don't see a soot number... or is is the "St 37 39". I presume that's in ppm. The iron is outstanding for the miles. I'm sure Dave Newton is going to dance with joy when he sees this.
TBN (Total Base Number) will tell you how much of the additive pack is remaining but the sulfation and nitration tells you pretty much the same thing. They are the percentages of 100 percent, with 75 percent generally being the allowable max. Sulfation is the inverse of TBN. In this sample, it was 22, or 22 percent of the 100 percent, which would also indicate a 0 TBN. In my own tests the sulfation percentage correlates pretty well to TBN.
Sulfation, nitration and oxidation are all determined by Infrared Spectroscopy. According to Wear Check, they do not make condemnations based on these numbers alone but 75 percent is the usual limit. Essentially, the TBN alone will tell the tale as much as it's needed to be told.
Edited by Jim Allen (04/11/11 11:00 AM)
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2229001 - 04/11/11 12:03 PM Re: '07 LBZ UOA @ 175,000 [Re: Jim Allen]
Meathead Offline
Loc: Upstate SC
You're correct, the 'St' number is the Soot reading. The unit listed for it is 'ct/ml.'
Still outstanding?
#2229270 - 04/11/11 04:26 PM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Jim Allen Offline
Loc: NW Ohio
Was this test done by CAT? They use that "counts/milliliter" thing rather than expressing it as a percentage. I don't know how to convert it to percent or ppm but based on stuff I've seen elsewhere 34c/ml MIGHT be around .5 percent.
Jim Allen
#2229764 - 04/12/11 06:28 AM Re: '07 LBZ UOA @ 175,000 [Re: Jim Allen]
Meathead Offline
Loc: Upstate SC
It was. I'm in the construction business, so have a CAT rep who stops by every other week or so. It was just the easiest way for me to get started doing UOAs on this truck.
Since I've become interested in it, and after reading and learning more on this site and elsewhere, I'm planning to pull two samples at the next OCI - one for CAT and one for Blackstone (their free kit is on the way).
...based on stuff I've seen elsewhere 34c/ml MIGHT be around .5 percent.
That'd be a good number, wouldn't it?
Edited by Meathead (04/12/11 06:29 AM)
#2229780 - 04/12/11 06:56 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Jim Allen Offline
Loc: NW Ohio
That would be a great number but I'm not so sure about it now. I really don't know how to convert that but I posted a question. You might contact your cat rep and help us all out by asking them how to convert ct/ml to percent. I have heard reference to a conversion chart on the web but, after a search, couldn't find it.
Jim Allen
#2229798 - 04/12/11 07:22 AM Re: '07 LBZ UOA @ 175,000 [Re: Jim Allen]
Meathead Offline
Loc: Upstate SC
I've done just that this morning, and will post whatever response I receive from their lab.
#2229887 - 04/12/11 09:08 AM Re: '07 LBZ UOA @ 175,000 [Re: Jim Allen]
Meathead Offline
Loc: Upstate SC
From the CAT lab:
"...the numbers you see are not particles per milliliter (that is for particle counts only), they are "UFM" or "Unsubtracted FTIR Method" numbers. These are based on absorbance of infra-red light at different wavelengths. You can convert the soot UFM number to percent weight using the attached chart. Simply look up the number on your report in the "Abs" column on the chart, ignoring the decimals, and to the right you will find the corresponding percent weight result. For example, your most recent soot UFM result was 37, so you would find the Abs line for 0.37, which tells you that your percent by weight is 0.56%. This chart only works for the soot number."
I'm not sure how (on this forum) to copy and post the chart he attached to this email, so I hope this explanation is sufficient.
Given his conclusion that the Soot reading for my UOA is 56%, please also tell me your thoughts about that.
Edited by Meathead (04/12/11 09:12 AM)
#2229992 - 04/12/11 11:13 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
Jim Allen Offline
Loc: NW Ohio
Well, .56 is outstanding for a 25K run. I've seen diesels over 2 percent at 10K. What is the time interval and is this mostly highway type driving. You can wail on it to much with soot levels like that. Can't believe D Newton hasn't commented yet.
Jim Allen
#2230889 - 04/13/11 08:47 AM Re: '07 LBZ UOA @ 175,000 [Re: Jim Allen]
Meathead Offline
Loc: Upstate SC
That's good news. I haven't seen this stated specifically anywhere, but based on the way you phrased that, I gather the Soot reading is cumulative, as well? If so, can I also assume .56 is no reason to give up on that load of oil just yet?
Would you suggest pushing the OCI to 30k?
Also, based on what I've read and learned here and elsewhere about UOA, I'm thinkin' I may pull a sample at the halfway point - 12.5k, to be able to keep a closer eye on things as I go beyond the 200k mark. Can you (or anyone else) offer any thoughts about that?
This most recent OCI ran from 08.13.10 to 03.31.11, about 7 1/2 months. It is primarily highway driving, but there's a fair amount of sitting in traffic highway driving there, as well. I do live in the Atlanta area, after all.
I'm not sure I follow that, exactly. I think you might be suggesting that I don't wail on it very often. That couldn't be further from the truth, actually. I drive pretty well like an old man the vast majority of the time. My biggest weakness, though, is another diesel truck (or a litle tuner car with one of those obnoxious flatulence-box mufflers, or a late-model muscle car, or a European sports car, or...) sitting next to me at a light, wondering if the incessant whistle really means anything. I'm a sucker for a stoplight-drag challenge, and those occur with remarkable frequency...especially when you're out lookin' for 'em.
The short answer: I stomp on it...a LOT.
Edited by Meathead (04/13/11 08:50 AM)
#2235686 - 04/18/11 11:08 AM Re: '07 LBZ UOA @ 175,000 [Re: Meathead]
dnewton3 Offline
Loc: Indianapolis, IN
I had the opportunity to confer with Meathead over on another forum, and I encouraged him to come over here and join us real lube nuts, so I've already had the priveledge of seeing his UOA info.
25k miles with that kind of performance really puts things in perspective. Especially when some would cringe at the use of the OCOD. Most impressive, would we not agree?
Someday, more people might realize that today's common rail diesels and quality lubes can just go a lot further than they first suspect. These ain't your daddy's lubes any more ...
Edited by dnewton3 (04/18/11 11:08 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
