I cannot think of a single advantage to using bolts instead of studs + lug nuts on wheels. My old Beetles had the bolts, my friend's BMW X5 has them, another friend's work vans are Sprinters and they have them.
It is more work to mount the wheel on the hub when using bolts and the X5 comes with a tool used to align the wheel to the threaded holes in the hub.
In cases of damage (cross threading, loose wheel) it is a lot less work to simply replace a stud than it is to try and repair the threads in a hub or, worse, replace the entire hub.
So, why do the German manufacturers persist with the use of wheel bolts? Is it just arrogance and a refusal to admit that, maybe, there is a better way?
