Originally Posted By: 440Magnum
Originally Posted By: Letter_K
Correct - I would think it is more likely the new fluid might have dissolved some varnish and containment that was holding together something. Perhaps a seal went bad and the gunk held it in place or something plugged up. It's all speculation on what caused the failure.
Yes, it is indeed all speculation, but I have a different one. When a failure happens right after a fluid change, I tend to suspect that its the process of purging all the air out of the clutches and actuators that causes the failure. When the pump is blowing the air out, you get the equivalent of "water hammer" in home plumbing when the last of the air goes out and solid fluid pressure hits everything. The fact that people tend to rev the engine in neutral to speed the process probably doesn't help
Old seals can be as hard as dry pasta, and my GUESS (yes, that's all it is) is that the pressure pulses crack the old rubber seals. The last transmission I rebuilt myself had a front clutch actuator seal that felt like ceramic instead of rubber, and it was cracked 2/3 of the way around the circumference.
Unfortunately, transmission problems are expensive and most shops just want to replace the whole unit.
I haven't had that experience yet, but then my last tranny rebuild was about 7-8 years ago. The shop re-worked the whole thing in-house, and added a few upgrades to address known weak spots (it was a 1993 Chrysler 42LE).
Your idea sounds reasonable as a reason for a failure. I think we all know that a fluid change is for the better and the tranmission is on it's way out if a fluid change kills it. The fluid should be changed, but there is always that slight chance user error or something with the fluid/process may cause a problem. However, the chance of a complete failure is probably minimal unless you already have clear indication something is majorly wrong with the transmission.
I'm very cautious about doing a cooler flush that drains the pan completely. I'm almost more willing to go 2 quarts at a time so avoid getting the pan completely empty, but that makes it hard to shift through the circuit and make sure it is completely flushed. Any thoughts?
I think I had that same transmission in my 96 Intrepid and that was the car that put the fear of a transmission failure in the back of my head. You were luckier with your shop. I was in limp mode and the car had enough life that if was worth changing the transmission. I made the decision to replace the transmission and less than 2 years later I ran into problems with the replacement. Hard shifting when hot and fourth gear that wouldn't come unless I backed off the throttle completely and pressed it again.
