F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
Best Oils for Direct Injection & Turbo Engines
by BobsArmory
08/24/16 04:45 PM
cheap upgrade to win 10 from win 7 s/n
by bmwjohn
08/24/16 04:25 PM
trimmer loses power when hot
by motor_oil_madman
08/24/16 04:21 PM
NAPA "GOLD" #1358, 10,080 miles CUT OPEN
by car51
08/24/16 04:01 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
118 registered (andrewlg, 2015_PSD, 29662, 2002 Maxima SE, Al, 11 invisible), 1736 Guests and 10 Spiders online.
58911 Members
66 Forums
253509 Topics
Page 2 of 2 < 1 2
#2535726 - 02/13/12 09:29 PM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
Carbon Offline
Loc: near Chicago
I suggest comparing the spectral analysis to the classic flame tests of qualitative analysis in chemistry. The flame tests are limited to the more easily ionized elements, but there is a relationship. I presume you did flame tests in lab.
Edited by Carbon (02/13/12 09:39 PM)
#2685226 - 07/16/12 01:53 AM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
lubrex1 Offline
Loc: united arab emirates
hi,
i recently bought an ICP for elemental analysis, Is there any body who could guide me about element's wave lenght selection etc.
#2994493 - 05/06/13 10:24 AM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
DriveHard Offline
Loc: Middle of Iowa
Seems to be a glaring error...
You stated
These rings have to reliably create a tight seal between the piston and the cylinder wall while travelling at up to 4,000+ feet per second
WOW! If that were the case, there would be thousands of sonic booms in our engine all the time!
I think you meant FEET PER MINUTE.
Nice work though.
Smile, it increases your face value.
2011 Silverado Crew Cab LT 6.2L/6spd
2008 BMW X3 3.0si Sport
Elio...?
#3931693 - 11/28/15 06:54 PM Re: A Chemistry Term Paper On My UOA [Re: tinmanSC]
Ducked Offline
Loc: Taiwan
Originally Posted By: tinmanSC
"This is basically the temperature at which the oil sample will start to combust in °F." Consider removing "basically" as it makes the definition sound ambiguous.
Perhaps also consider NOT using °F. Centigrade looks more scientifically literate.
"and dirt that gets sucked in through the engine’s intake system." Technically it gets blown in, as a reduction of air pressure in the intake causes the high pressure outside air to push it's way into the intake. But, perhaps this is best left uncorrected. smile
Indeed, because if you "corrected" it, you'd have to explain your "correction", and then you'd look like a pedant.
"The TBN (Total Base Number) is a lubricant’s reserve alkalinity measured in milligrams of potassium hydroxide per gram of oil." The reserve additive can also so be Calcium Sulfonate.
Leave it alone. You're saying how the reserve alkalinity is measured. Doesn't matter in that context what the reserve additive is
#3931738 - 11/28/15 07:39 PM Re: A Chemistry Term Paper On My UOA [Re: Ducked]
Ducked Offline
Loc: Taiwan
Or even Celsius.
(showing my age)
Page 2 of 2 < 1 2
