Post your latest oil change
gf's 95 Nissan Frontier 2.4
out: M1 0w30
in: Durablend 5w30 + ARX
AZ oil change special with Bosch 3400 substituted for FramTG
Gotta get rid of my aging stash of ARX (4+yrs old) before they go bad or start leaking
1999 Taurus Vulcan V6 with 130,000 miles
Out- M1 5w30/Pureone 20195
In- Maxlife Full Syn / Full Size Motorcraft FL400s
Time in service 5500 miles and 8 months
1996 4.3L Chevy Blazer
209,600 Miles at time of oil change
9,600 miles on oil (Probably two quarts of makeup oil as I recently switched this over to synthetic)
Out: 4.5 quarts O'Reilly Full Synthetic 5w30/Quaker State QS3980 (wouldn't have run that long on this filter but thought I had a Fram XG installed... oops)
In: 4.5 quarts Mobil1 5w30 Full Synthetic/Mobil1 M1-201
Will run this oci 10K miles
2008 Corvette Z06, 5900 miles
Out-8 Qts. Amsoil 5w-50, AC Delco filter
in -8 Qts. Amsoil 5w-30, Purolator Pure one filter
3 3500 Savanas with 6.0 gas engines.
Each got 6 quarts of Valvoline Synthetic blend 10w-30 and a Pure One filter.
12-14 zerks on each. Used a whole tube of grease!
Festiva:
Changed the oil filter and added a 1/4 quart of ST HM 10w40. Oil light was staying on longer than it should and more valve train noise. Filter had been on there for 5k with Maxlife 10w30 originally and 1 quart top ups with ST HM 10w40 every 1k. Consumption has dropped since the valve stem seals were changed but don't know the extent. No consumption in 750 miles although but the rear main seal weeps still.
Vehicle: '04 Honda Accord I4
OUT: pp 5w-20 & full filter @ 5400 miles
IN: pyb 5w20 & pureone
**pp has been used for the last ~40,000 miles. This is the Honda's first taste of conventional oil.
'94 Olds Cutlass Supreme 3100 approx 4k miles
Out: MC 5W-20 with AAP AC Delco PF 52
In : 4.5 qts Meijer 10W-30 High Mileage SL rated with AAP AC Delco PF 52
'04 Pontiac Grand Am 2.2L Ecotec 6336 miles
Out: MC 5W-20 with Napa Gold made in Poland (no holes but very hourglass shaped)
In : 4 qts GC 0W-30/1 qt 10W-30 Edge with AAP AC Delco (Hengst USA)
