Originally Posted By: unDummy
It skipped once. Then it'll skip again in a few months. Then it'll skip again in a few weeks. Then it'll skip again in a few days. Then it'll skip again in a few hours.... and then you need a rebuild. If it repeats, I recommend that you trade it in!
Unfortunately, that was a the situation I had with a 1996 Dodge Intrepid. The first time I was on a turn lane yield rolling slowly and I thought someone had rear ended me. Thought to myself, what was that and it must have been a fluke. Weeks later same thing happened again. A few weeks later was pulling up to a stoplight and it turn green while I was going 25 MPH hit the gas and went into limp mode.
But you have only so many options and worse case you unload it and probably lose thousands in value or you end up down the road spending thousands for a tranny. Best case it was a fluke.
You'll probably have a good idea if it happens again in a few weeks or a month. I'd change out the fluid and filter and check the pan for any debris.
