I'm considering switching to conventional PYB for the Summer (May through November) and Synthetic for the Winter (Nov-April) here in Boston. I'm not concerned with wear or the cleaning abilities of the oils, since the OCI will fall comfortably in the 5-7.5k range. My question is whether switching back and forth on a yearly basis will affect any of the engine seals. I can't seem to find a consensus on this issue by searching.
The car in question is 2004 4cyl Honda Accord seeing about a 60/40 split city to highway miles annually. The car has never seen straight conventional oil, save for the factory fill, changed at 4200 miles. The next 40,000 saw Kendall GT1 semi-syn at 5k oci and the last 40,000 PP at 5k OCI.
The Wintertime synthetic use would be for cold start peace of mind.
