Originally Posted By: 440Magnum
Originally Posted By: mikered30
I thought toyota/lexus solved this issue, or at least minimized it better?
They stuck a big band-aid on it by using a central injector to "wash" the manifold and intake valves. Its about as elegant as when the Ford Powerstrokes were injecting raw diesel on the exhaust stroke in order to fuel the DPF regeneration cycle: it works (sorta) but leaves you saying "there has GOT to be a better way!"
I disagree. I think it's a perfectly workable solution. It's the reason engines with carburetors and TBI rarely developed intake deposits even with EGR (assuming adequate detergent levels in the gasoline).
If you've got EGR and PCV filing the intake manifold runners with blowby and exhaust gases, there is no way to eliminate buildup without having some mechanism to continually wash down the interior surfaces of the intake manifold. With a carburetor or TBI, this happened from the minute the air/fuel mixture entered the manifold. With port injection, the valves got washed but the manifold interior could and often did become a mess. Now with DFI, nothing is getting washed, hence Toyota's solution.
