Here is a friend story who has a 1996 Nissan Altima 4 cyl. with auto trans he bought used. Below is his problem with MIL codes displayed. Please help if you can....
"I am having a problem with the 1996 Nissan Alima GXE. Every so often it begins to stall. It can happen when I am on the highway or while driving around town. It is more dramatic while in town, to the point that it will completely die. It then takes several tries to get it restarted. The car will run fine for a couple of days, then start acting up. It feels like it is either not getting gas or not firing. When on the highway, you can feel it loose power.
After researching the codes online, I read that that combination of codes could indicate a bad fuel injector. Using the manual, I checked each one along with the wiring to them. They all checked out normal. "
By the way, the codes I am getting are P0325 (Knock sensor), P0335 (Crankshaft position sensor, and P1336 (no definition). Because of the no definition I did the online research and came up with the possible fuel injector problem.
I had Cam drive it, and she said that the engine was strong and thought that there might be a fuel pump problem. That is when we pulled the pump and checked for foreign objects. There was nothing in the tank but gas. The screen was clean and the pump ran good. We tried it several times connecting it directly to the battery.
To date I have given it a full tune-up (distributor cap and rotor, wires, and plugs), replaced air and fuel filters, and replaced the crankshaft position sensor. I have checked for loose connectors, but found them all locked in. At this point I am stumped. Can you shed any light on the problem? Any help is greatly appreciated.
