So, I've just purchased a 2004 Gravely 34Z with 182 hours on it. Naturally, the first thing I'd like to do is change the oil.
Reading through the owner's manual for the Kawasaki 15HP engine that is on this thing, Kawasaki states that in my temperature range, to use either SAE 30, 10w-30, or 10w-40. Then, as many of you are already familiar, they state that I should expect some oil consumption if using a multi-grade viscosity oil.
So, what is it about this Kawasaki engine that causes a multi-viscosity oil to get burned up? Is it because it is air-cooled, rather than liquid-cooled? And if so, why? Or is there something else going on here?
Thanks,
Bryan
Thanks,
Bryan
