I've got a question about wiring a spit duplex NEMA 5-20R to a 208v, 20A, 2-pole circuit breaker. I tried searching the internet and couldn't find a direct answer.
In a split duplex like this, each receptacle in the duplex outlet is wired to one side of the 2-pole 208v breaker, which gives two independent 120v single phase outlets in one duplex box. The beauty with this setup is that both outlets on the duplex box get turned off when the breaker is tripped. Each outlet has it's own hot, neutral and ground wire going back to the breaker panel, which makes them independent circuits that are controlled by the same circuit breaker.
So, question is ... can each independent outlet carry 20A if the 2-pole breaker is rated at 20A?
I believe if either one of the independent outlets exceeds the 20A rating of the breaker, then the the breaker would trip and both outlets will be powered off. Is this true?
