I'm thinking it's time to change out the bearings in my alternator. It's developed a bit of a chirp when cold (and occasionally when warm, although very quiet). The sound is definitely coming out of the rear bearing in the alt. However, if I pull the belt and turn the alt by hand, it still turns freely and smoothly, with no catching or anything.
I've put about 1500 miles on it since it first became noticeable, and it doesn't seem to be getting worse. Is there an easy way to add some grease to that bearing (not sure if it's a sleeve type or a ball bearing), or should I just plan to pull the alt and do the bearings when I have time?
