MX2T is arguably the finest two stroke oil ever made. Here is a mail from Mobil in regards to an injector application. Use your stash with confidence. I'm going to keep working through mine. Too bad I'm down to about 5 gallons now. :-(
"Thank you for your inquiry. The Mobil 1 MX2T became Mobil 1 Racing 2T and was cancelled in the US in 2007. It is OK to use the Mobil 1 MX2T 2-cycle
> motorcycle engine oil in oil-injected 2-cycle engines.
> Technical Support Engineer (WJF)
[email protected] wrote:
>> Good day. I have used (and really like!) Mobil 1 MX2T in my motocross
> bike as a premix application. I understand that MX2T is not specifically
> recommended for an injector application. Without disclosing any proprietary
> information, can you please give the reason that MX2T is not recommended in
> an injector application? As a 30 weight oil, it certainly is in the proper
> range as far as viscosity. Several people are using it in the their Jetski
> and snowmobile injector tanks with excellent results as far as wear and
> cleanliness. That indicates to me a wide temperature range of pumpability.
> So what is the story? Please reply, I'm well stocked on MX2T, and want to
> run it in my 2 stroke scooter.
>> Thank You,
>> XXXXXXXXXX
